The 225/70/19. 5s are virtually identical in height as the 265/70/16s.
If you will go to Ricksontruck.com they have a really slick little app that you can plug in your specs on tires and it will tell you the the ratio EQ and the speedo change difference. But with the 225s, I doubt you will see any difference.
With my truck, my speedo was slow 3 mph from the factory. After I installed the 225s, my speedo is dead on with my GPS and the roadside radar devices in work zones.
When I step up to 245s, I'll pick up another 3 mph.
Last but not least, lets bring this into focus... ... ... . If you were to have a new set of Michelin 265/70/16/17s installed on your truck, you would spend at least $850... ... ... ... ... ... ... . If you buy the Visions, you get WHEELS and TIRES... ... ..... and a set of tires that will probably out last a new set of LT tires... ... ... ... .
mi dos centavos... ... .....
