1969 Ford Crew Conversion......
Ideas...
Trucks! on SpikeTV
Rebuild parts are coming in so I'm back to work on the front axle... . Got the front axle all u-bolted in there... but the u-bolts were too short. Oooops!
:rolleyes:
New inner seals installed and double checking the lash... thinking back, I don't know why I didn't just put a LSD in it while I had it all apart? I guess I'll just have to do that job over again later... . :confused:
New spindles and complet king pin rebuild completed... .
:cool:
Decided to remove the pre-load spring set up on the king pins... . the new set up uses the set screw to actually pre-load the king pin. Advantage here is that it will keep the front end tighter and with the 38's avoid any front end wobble due to balance or other... .
:D
Mounting the tie rod on the high side, so I had to go with heim joints (rod ends)..... the bolt in the pic was not the one used, that one is way too small!
:D
What all did you get from them?
If anyone is curious WFO Concepts
They set me up with the crossover/hi-steer, drag link, rod ends, tie rod, pitman arm and the king pin pre-load set up... . best to try and call them as they don't seem to respond to e-mails? Probably too busy in the shop... . I need to call them for some brackets to complete my four link/coilover front.
:rolleyes:
First time I've looked at this link, you do amazing work. Even more amazing is that your doing this in your driveway. You have the patience of a Saint to not rush through this project. Well done...
Thanks!
There have been a few occasions when I felt like quiting! Just got to get r done!
:D
Here is the correct bolt... . I'm using a full shank bolt for greater shear strength and will cut off the extra threads. First drilling out the steering arm.
OK... motor going back in so I can get to work on the trans and t-case mounting... . since I already had the NV4500 from my last project, I will be using a married t-case... Ford driverside drop NP-205.
The 1993 motor had the wrong adapter plate for the NV4500... . the correct plate has all the same bolt paterns, just an additional 1. 000" deeper (thicker). .
89-93 plate..... @ 1. 250"
:cool:
And the correct plate @ 2. 250" Also just another bit of information... . the 2003 and up adapter plates won't work only because they changed the mount to the block to a asymmetrical pattern as the plate now seals the back of the cam bore...
:rolleyes:
Test fitting the NV4500... . need to see what mods that I need to make for trans mount and front drive line clearance.
