2nd Gen Non-Engine/Transmission 1995 2500 Right rear Break drum
Engine/Transmission (1998.5 - 2002) The perfect towing Machine
1995 2500 Auto--stock with 275,000 miles.
The direction to move the star wheel so I can get the shoes out of the hub wear?
I can move the drum around by hand so it is plenty loose. I'm thinking the shoes in the drum wear is keeping me from pulling the drum off.
Down with star wrench hand moves adjusting wheel up or move the wrench hand up to move wheel down.
Thanks for your Time and Help.
RMcKinney
I think you want to go down with wrench hand, you might have to use small screwdriver to hold adjuster out of the way.
Thanks.
That worked so I'm done with that.
Now I'm trying to get the Driver Door back on.
The door was shut when I got back to install the hinge so I'm trying it get it on.
