... suburban... RV... tank... something like that :-laf . Actually, the whole thing came about as a result of owning 6 other trucks in the past 13 years, including an '87 Ramcharger LE 4x4, a '78 short box club cab 1/2 ton 4x4 w/ a 440, a '79 Rancharger LE, a '78 long bed club cab 1-ton with a 440, a 74 long bed crew cab 4x4 dually (home made, now deceased... but learned a LOT), the '93 diesel, the '85 crew cab dually, and lastly my '78 Ramcharger.
In the process of owning (read - test driving) all these trucks I discovered what I needed to have, and for the longest time I was going to try to build one truck to do it all, and essentially the SuperCrew will be it, but I love to go 4xbashing, and I'm not about to take my big beautiful BLU OXX in the thick backwoods and beat it all to hell - so the decision was madde that I needed two rigs - one to serve as the long-haul RV type, and the other to be the off road basher.
Since I love Ramchargers (IMHO the ultimate sport-utility vehicle) I found the last one I'll ever own - my nice little '78, in Denver for $800 bucks. It's being fitted with the SRW rear axle from my '93 diesel (a Dana 70 w/ a posi), and I just got a '79 Dana 60 from a 1-ton. Both will be 3. 54 ratio which will allow me to get to the mountains without an overdrive, but when in 4-low axle gears are nearly indifferent. The rear will have the posi and the front an electric locker - just coming on the market in Novenber. It's also getting the bulletproof divorced np205 and stubby 727 (from the deceased crew4xdually in my readers rigs) which will make the little ole Ramcharger a part time 4x4 with 1-ton axles and new 1/2 ton Skyjacker suspension. The fronts are the 2. 5"-over packs and the rear are the 6" over packs, which will allow me to remove the 3" lift block from the rear completely, allowing the leafs to bolt directly to the axles - the best way to avoid axle wrap and allows the most articulation. The engine, a factory 400" big block, is getting a fresh Crower cam, head work, new Carter 625 AVS, and fresh chain, pumps, etc, just to remove 26 years of 'old'. After all that's done it'll pretty much be a nearly indestructible off road beater with lots of power and guts. The part time will be easy on tires, and the 4x4 will be a real 4-wheel drive. Should be fun, but that it what the diesel is not really meant to do.
The diesel is the long-haul RV that'll tow any thing, any time, any where. It'll be 4WD but that's more for bad weather and mild trail riding/camping, etc. With the twins and DTT and Dana 80 it'll handle all kinds of power and haul the trailer without even knowing it's back there, right up I-70- going over the little hill called the Rockies.
I've been wanting to do these two rigs for years, and am finally at the point that I can make it all happen. Gonna be a fun Winter - sheesh I can't wait!
Can I write a book or what! And yeah, I'm single... . but if my wife calls get her number for me!
- Sam
