1st Gen big rig wheels
1992 D250 Won't start
Killer Dowel Pin Jig
I have a 91.5 w350 5spd with custom flat bed. Picked up a set of 22.5 big rig wheels, anyone have any idea how much lift I need to run 11r tires? If so where can I order it? The truck has very stiff springs now and I don't want to soften my ride much because the flat bed is very heavy and gets alot of use. Any help would be much appreciated!
The issue you will have is no lift spring ive ever heard of are stiff as your factory springs, they claim to be the same load rate but i dont buy it. as for fit do you know the overall height of your tires? I know they are a lot smaller but my 33.5" 245/70-19.5 fit with on with a stock springs.
The issue you will have is no lift spring ive ever heard of are stiff as your factory springs, they claim to be the same load rate but i dont buy it. as for fit do you know the overall height of your tires? I know they are a lot smaller but my 33.5" 245/70-19.5 fit with on with a stock springs.View attachment 95970
The 11r tractor trailer tires are about 41.5 inches tall mounted. I'm guessing that I'm going to be making my own lift kit!
