2 micron cat 1r740 filter
2003 engine noise
DC Lift Pump Relocation Kit Instructions Available
2 micron cat 1r749 filter
made up a 2 micron filter between my stock filter and cp3 with all cat parts. i think it came out good. seeing about half a psi diference at full throttle on fuel pressure. stock intank pump rest of the truck is stock
How much did the head set you back?? Part #?
How expensive are those Cat filters?? I heard they are fairly inexpensive??
Your setup looks good... almost looks like OE.
steved
I would love to have my 2-mic filter right there but that is the exact spot my Apps sits, thanks Dodge.
I had the same issue. I fabricated a couple of brackets out of a piece of angle iron and flat steel, and mounted a perma-cool filter there, anyway. :D
Looks good. Where are you measuring the pressure?
I can't help but wonder what will happen with all these auxiliary filter systems when the temperature goes down to, say 10 degrees. Probably not a problem in California though. If you do see some cold temps please do post up how the 2 mic filter with the stock lift pump performs. :cool:
At least on our C12 Cat, the filter restriction gauge is normally ~2". Goes to almost 5-7" when the fuel is cold. Comes down when the fuel warms up.
I use one of those Cat filters between my aux tank and the main tank. I also use Howes year round. More Howes during cold snaps. Good installation and pics. I would like to get rid of the banjo bolts and increase the amount of fuel available to the engine fuel filter. Any kits out for that?
I have the Cat. 1R-0749, 2 mic. , fuel filter serving the auxillary fuel tank on my '03. It's been there for well over a year & has worked well.
The filter head (mount) is a Cummins product.
I believe that the 1R-0749 is the longer version of the other filter that has been mentioned. Mine is about 11" long (filter, that is!!!).
Joe F. (Buffalo)
Joe F. (Buffalo)
im sorry thats what it is 1R0749, i dont know why i put 740
www.glacierdieselpower.com makes good kits. I have their 2 micron kit sitting in my living room begging for an install
The 1R0749 crosses over to a WIX 33674 or NAPA 3674. NAPA is showing the price at $21. 89, don't know how that compares to Cat's pricing.
FF5319 fleetguard crosses to that 0749 cat... i've got 2 of them [±9. 5" tall] sitting at home, along with 2 ff5320's [±7" tall] . . they both were under $20cdn/each from cummins [missassauga, ontario, canada]. they had instock the 19's, but the 20's are were not in stock
Careful with filter number cross references
Be careful about cross reference filter numbers. I am in the process of putting a Stanadyne FM1000 between the stock filter and CP3. The biggest delay finding the right filter. I have discovered that many of the cross reference numbers do not necessarily match the micron size or especially efficiency. I have finally found a Donaldson filter that will work. Now I just have to find someone that can get it for me.
