yea hopefully i will have something thats set in stone soon for all that see what we do.
steved said:Ryan: Is your setup a return? Does it cycle fuel back to the tank like the FASS and Airdog??
steved said:http://www.fleetguard.com/fleet/pdf...hures/hydraulic_filter_guide.pdf?SMSESSION=NO
For those of you wanting to know about the FG hydraulic filters used in the FASS...
300psi working pressure, 35 GPM (not gph), b>200 = 12micron, b @ 75 = 10micron, b @ 2 = 3 micron... and if I read this right, that means it is greater than 99. 5% efficient at 12 micron, 98. 6% at 10micron, and 50% at 3 micron.
Or in theory, not much better than a stock filter, albeit, we are no where near it's rated capacity at 1. 6 gallons per minute.
steved
Diesel Power said:maybe i read it wrong but it looks better than the 2 microns ratings, if you factor in the gph diference... ...![]()
steved said:For the HF6604?? That's about the best filter (for filtration) you can get on the FASS...
The HF6607 is the next best FleetGuard from my research... but there are also others that are similar.
I was just spewing the ratings they had listed...
I will add that I don't know how to figure the micron efficiency for different flow rates...
steved
Diesel Power said:your right the 6604 and the 6607 are the best so far, but down th eline i saw other much better rated filters that had the same head design, i will call them today and also i found good filters from donaldson absolut 3 microns that seem to fit what we need.
steved said:Which donaldson? The P169392 is a direct fit according to them... and equal to the HF6604/HF6607.
steved
steved said:Shoot, I should have also said that the HF6600 series is 3. 67"D and the others are 5. 02"D... they wouldn't clear the brackets... which is a shame as the one is rated for 98% @ 2 or 3 micron... at still well over the flow rate we need... I'm considering running on of these just downstream of the FASS (and upstream of my guage) for added protection...
steved
Diesel Power said:ok after a long but fruitful day i found what we need, the water fuel separator is fine, it will flow well over 200gph. but the other filter is the one we need to replace. i will have a part # and all as soon as i can get case quanities, im still looking for avalibility. Oo.
steved said:For some reason I never got notified of a reply to this thread...
What are the specs on the filter?
Will this be for the new FASS design or the older units? I assume it is a Donaldson?
steved
TWest said:The Pressure will Kill the Rating... That"s the problem with High Volume Rates=Mic ratings.
