2 questions about fuel press. guages
Digital Guages?
ISSPRO EV Electric FP Gauge update
1. ) Do the Isspro fuel pressure guages come with all the tubing and fitting neccesary to hook up?
2. ) Which one do I need? 30# or 100#?
I have a 97 12v. Engine is stock for now but as state a hundred times BOMBs are on the way.
TIA
Russell
With your 12 valve you need a gauge that reads 40 psi minimum as your normal FP will be 22-30. A 30 psi gauge is too small and a 100 psi too big, for this reason many folks are using 40-60 psi boost or water pressure gauges.
I didnt see a 40 or 60# guage from Isspro, where else is a good place to look at?. I am trying to keep all the guages similar in appearence. TIA
