I installed the in tank Mopar kit earlier this year. I did have an issue with the pump seal slipped down on one side and leaked, ended up draining about 15 gals and pulling it and repositioning it, but that was my fault, working by myself and trying to hold the pump down in place against spring pressure and starting the nut at the same time.
I am yet to get the computer re-programmed as the instructions call out. The dealer nearby with the DRBIII system claims it has a broken cable and was unable to do it and is not interested in repairing it.... sheesh! He recommended another dealer about an hour away, so I need to get with them. The fuel gauge will be off with the installation of the new pump, but I have become used to it now.
Be aware you have to access a connector that is behind the LH wheel well shroud, so you will need to remove it. 8ea 5/16 hex head screws. reinstall them by had to avoid stripping them and you will be OK. There are two "christmas tree" cable holders that you need to find and push back thru FIRST. One is down low just aft of the upper control arm (if 2WD) and it is for the anti lock sensor wire. The other is up higher near the middle and it a retainer for the throttle cable, which runs from the pedal to the position sensor on the bottom of the fuse box.
As an alternative, you could buy a replacement fuel pump and hose, keep the proper allen wrench with you and just be prepared to change the lift pump when it fails.
Charles
