With stage three injectors and a ttpm I had a bad stumble at 2800 rpms until I added the pusher pump Kieth sells.
Where can I get the banjo fittings for the 2003 to install a fuel gauge?
Originally posted by TDRadmin
As long as it is delivering positive pressure to the high-pressure fuel pump, the gear pump will take care of the rest.
The European version of the Cummins common rail engine does not have a lift pump. The gear pump takes care of delivering fuel -- as long as you don't loose prime.
Originally posted by AndyMan
That sounds nice, but would you have to disconnect it every time you changed the fuel filter? I'd be afraid of leaks I think.
yogibear said:Mine is hooked up the same as yours, 8--8. 5 idle, 7 at cruise, 6 at wot, empty or pulling a heavy load. I noticed the noise also. Let us know if it changes when you move it, or use a snubber. I have the di pricol guage with antifreeze in the line from banjo to sending unit. I didn't think this would transmit the noise like it does.
gsbrockman said:I just had my fuel pressure gauge installed this evening and decided to do a search and reviewed many, many threads. On a cold engine, my fuel pressure was around 5 to 5. 5 psi at idle. After a 45 to 50 minute run at speeds between 60--70 mph, my gauge stayed near 5 psi, but on a hot engine, the idle was up to 7. 5 psi. Greg
