Apoligies if I missed the answer to a search here.
I just noticed a small 1" spot on the concrete below the front of the engine. The truck has 60K miles. Coolant is down about 1/4" in the reservoir bottle. Looking under neath I see a drop of orange/red coolant on the front side flange of the oil pan. I can not see any leaking hose fittings. Could this be a water pump bearing failure? A flashlight shows tiny drops flying past behind the fan blades. How should I proceed? Dealer wants 695 parts and labor. 325 for the pump and gaskets assuming its a water pump. Is there a good way to verify the WP is bad? I've heard this is a relativley easy job and the truck needs a coolant, hose and belt replacement anyway...
TIA.
TIA.
