ENafziger said:Interesting... the link indicates that the speed of the 2007 engines will be governed to 2600 rpm. I work at the National Transportation Research Center, and rumors on DPF costs on Class 8 trucks for 2007 are in the $6k - $10k range. While cummins says the DPF will go 200k - 400k before needing replaced, the cost of a new filter @200k may be more than the cost of an engine rebuild. Moreover, with the additional computer controls for regeneration strategies, careful back pressure monitoring, and VGT control schemes, it seems as if modifying these trucks will not be an option... or a much more complicated and expensive option at least. I'm liking my '06 better every day!
FATCAT said:I have to say that the first major hurtle that ANY performance manufacture would have to do is break the computer code for monitoring the DPF and the regeneration procedures. Once these can be identified, then can be shut down and the DPF and fuel lines to the exhaust can be cut out and removed. That might be the extent of "performance mods" for the first few years of this new engine ... . anything else like fueling mods and what not will be for naught if the engine can not breath properly.
If the exhaust system can not be removed without the engine computer going nuts, then I will predict that the market for the Cummins HD Dodge trucks will come to a screeching hault very shortly.
Who here at the TDR would be willing to spend 10+ thousand dollars over a gas model for the same truck and then have to spend some $6,000+ for a new DPF and exhaust system after 150 - 200,000 miles? Not me I can tell ya.
The 2005-2006 models will be worth their weight in gold in the coming years ... you you guys who own one of them now BETTER TAKE GOOD CARE OF THEM for the forseeable future.
