You could almost pay the for the new truck with what you could get for it, if it had a NV5600.I'm trying to restrain my self by finding excuses and reasons not to trade in a perfect garage kept '03 dually with only 40k miles. :-laf The $$$ probably will be the limiting factor.
Bill
Im sure thats what the Ford engineers were saying when they put 3:31 gearing in the 12 model 3/4 ton P/U... but in the real world, while the gears may be the best "compromise" the fuel mileage is going to drop like a rock when towing at max gvw. . guess im jsut old school, I would rather have 3:73 or 4:10 and take the slight unloaded fuel mileage penalty, but not cause it to drop so bad when loaded. (due to constant backshifting)I too was concerned about the 3. 42, as my column in the next issue of the TDR will discuss. Afterwards, past the due date for the column, I did more thinking and realized that 3. 42 is OK, you just need to go from 6th into 5th when towing a load--and the transmission is programmed to do that as needed. I also was privileged to have a 40 minute phone conversation with the Ram Powertrain Integration Manager. I came away feeling that if you aren't using the Ram primarily near GCVW meaning towing a very heavy trailer, the 3. 42s are going to give better fuel economy and work well up to the 17,000 or so trailer weight the SRW 3500s are rated to tow. The new engine is happy and fuel efficient from 1200 to 2000 rpm. As stubborn as I can be (lol), I came away convinced by him.
Yes, you can downshift to achieve a final drive ratio that allows the engine to remain in the torque band at your chosen or state mandated road speed but you've given up the load startability provided by 4. 10 ratios.
I agree that if your trailer is close to or above the GCWR for the 3. 42s, you should have a dually for stability and the 4. 10s. One without the other is not the safest route. Actually, differential internal friction will be lower with the lower numerical ratios; they have more pinion teeth and larger pinion diameters. [/QUOTE]
Yes, I accept that but the transmission and driveshaft are feeling greater resistance therefore more driveline stress.
