2014 rear suspension changes
fuel filters 2013+
Tires and wheels
talked to the dealership, truck is built, and in some sort of process..?? said that once its put into transit they will receive a ESD. I didnt order this truck, and I do not know what the color combo will be, but its suppose to be a Laramie with 4:10 gears.
The pictures of the 2500 rear suspension look like what drag racers call a four link with panhard bar and sway bar. Much more complicated than the hotchkiss leaf spring design used for years. Four link suspensions with spherical ball connections (no rubber) handle 1,800+ horse power. The pictures showed the standard large bushings, I suspect some of the performance vendors will have polyurethane bushings or can make them if there is more slack in the suspension than desired.
