24 Valve Boost Relocator
Towing W/ Piers HX-40 super turbo
Lund Lunar Visor
I HAVE BEEN TRYING TO GET A 24 VALVE TO RESPOND FASTER
WITHOUT SMOKING, AND THIS RELOCATOR REALLY WORKS
I INSTALLED THE BOOST SENSOR IN THE COMPRESSOR HOUSING
OF THE TURBO GIVING THE ECM VOLTAGE FASTER! SIMPLE
A FEW WIRE EXTENSIONS, A PLUG AND YOU GET UP AND GO!
:) What are your expectations with this configuration and do you have any pics??? Miles per gallon, are you looking for an improvement?? Some data please when availabel. This sound interesting. :D :D Good luck.
I DONT KNOW ABOUT FUEL MILEAGE , BUT THE RESPONSE
IS A LOT FASTER BECAUSE A FUELING BOX ADDS TO WHAT
THE ECM IS DOING TO THE FUEL PUMP, SO UNTIL THE ECM
STARTS FUELING A BOX IS NOT WORKING!
I USE A BLUE CHIP BOOST FOOLER EXTENDED TO THE TURBO
COMPRESSOR SIDE.
THIS GIVES BOOST FAST, BUT NEVER OVER BOOSTS THE ECM!
IT DOESNT AFFECT THE END RESULT OF POWER OR TORQUE
IT JUST GETS YOU UP AND MOVING FASTER!
404-363-3322
Relocation of the MAP sensor seems look a good idea... less pressure drop on the hot-ter side of the IC... quicker spoolup as the ECM will read higher pressure quicker, at least until the boost module clips it.
:) Have you measured the difference in time with this relocation?? Is is in seconds or milliseconds? I guess the question is in a straight line uphill acceleration, what is the time difference?? Where did you come up with this idea?? :D :D
