275's,Performance,Mileage-Before & After
Bummed out
any power increase from removing catalytic converter on 96 cummins?
There has been a lot of discussion about 275 injectors, performance and mileage. What follows is my experience on the installation on a 2001. 5 extended cab 4x4 3500, six speed and 3. 54 RE. The only other mod that the truck has is the 4in. Jardine ex. Plus I have EGT and boost gauges. The 2001. 5 is my 3rd Dodge turbo. Previously I had a 96 12 valver w/ automatic and a 98. 5 Auto. Both had 3. 54 RE. They were both great trucks but I had an uncontrollable yearning for the 6 speed ETH, so I replaced the 98. 5 last fall.
STOCK RESULTS:
In November I took a 6,531 mile trip from Seattle to Niagra falls. I should add that I carry a 11 ft 6 in. Northland Camper that weighs in at 4000 lbs. plus, fully loaded. Gals of fuel used 585. 8 which gives 11. 15 mi/gal. The worst mileage was 8. 1 bucking a head wind so high that we eventually stopped. Driveability was good but it just seemed like it needed a little extra umph! (H. P. to you purists)
RESULTS W/4in JARDINE EX. ALONE:
Absolutey no mileage improvement over stock but it did seem to spool up better for a little better response.
RESULTSW/BOSCH 275's and 4 in JARDINE EX. :
The truck was loaded the same as stock with the 11ft 6 in. camper weighing 4,000 lb. plus. On this trip we drove 5,268 miles and used 471. 9 gal of fuel. Doing the math the average miles /gal equals 11. 16 or . o1 mi/gal better. However, the driveability of the truck was dramatically better. Where I previously had to shift down to make it over a mountain or incline it was not necessary or you were one gear higher. Horse power and torque were very noticeably improved without any sacrifice in mi. /gal of fuel. My worst mileage again was bucking a very high wind coming out of L. A. where I got 8. 9mi. /gal. Also,very similar to stock.
EGT & BOOST
On some very steep grades in Mont & Utah the EGT got into the yellow around 1150 deg F. , however, this could be quickly cured by backing off just a hair or shifting down. I saw nothing that was of concern. Max. boost(remember I am stock) was about 24 at which point it dumps fuel and the boost drops back to 22.
In summary, I have experienced a very noticeable increase in power. While I have not put the truck on the dyno the advertised claim of 40 to 50 hp with a correspondening increase in torque would seem to be accurate. Driveability of the truck is much better than stock.
2001. 5 ETH 3500 6spd. 4x4,3. 54LSD,all avail. opts. incl. leather,s. s. fender trim,s. s. bug guard,stull running boards and custom flaps,line x bed liner, BD injectors plus ISPRO EGT and boost, pillar mt.
Hi dad, glad to see you finally put up a post!
Edit: thanks for selling me your 98. 5
98. 5 3500 SLT Quad Dually 4x4. 3:54 Auto, Waterfall Blk on red. Custom dually flaps, Rhino lining, All acc's w/leather, Muth signal mirrors, Catz MSC's, 55watt back up lights, Optima Red Tops,
BD exhaust brake, Banks EGT/Boost/Temp gauges, Mag-Hytec DC&TP, SS bug screen and fender trim,SS Stull diamond line running boards, SS 4" turn down.
My Dually
[This message has been edited by Justbeamn (edited 03-22-2001). ]
Great post, Max!! #ad
Good long runs to average out the terrain issues and in the same season to eliminate fuel variation. Good objective data.
Thanks for the post and the effort.
<font color=#990000>~<font color=#990000> '99 2500 SLT <font color=#990000> ~ QC ~ 4X4 ~ LB ~ Auto ~ 4:10 LSD ~
<font color=#000000>*<font color=#990000> BD E-brake<font color=#000000> *<font color=#990000> BD Autolock<font color=#00000> *<font color=#990000> Gear Vendor OD<font color=#000000> *<font color=#990000> Jordan Ultima 2020 T-brake <font color=#000000> *<font color=#990000> Bullhide spray-in Line <font color=#000000>*
<font color=#000000>*<font color=#990000> 2k Komfort 5'er - 9,700 lbs <font color=#000000> *
<font size=-2>... Lookin' for the 'RE' to go in front of my 'TIRED' so's I got more time to Play!... <font size=-1>
[This message has been edited by Rattlin (edited 03-21-2001). ]
Sounds exactly like my conclusions. I have logged every tank of fuel with odometer mileage since new (now has ~40k miles). I have added, in chronological order: 285/75 tires (came with 245's), 275HP injectors w/ boost module (yes, a boost module does help even the 275's), Power Edge, DTT Valve Body, EZ Edge, DTT Torque Converter. I have also used different fuel additives. The ONLY place anyone can see any difference in my mileage is when I changed the tires - I have 4. 10 gears and the mileage went from 14. 3mpg to 15. 5mpg when I replaced the tires (now running lower rpm's at same speed). Yes, I correct for the tires (multiply odometer reading by 1. 077 to get true miles - this is based on the difference in diameter and, therefore, circumference of the tires). No, I don't pay any attention the trip computer - it shows over 20mpg - I wish! None of the other mod's have improved my mileage, nor have they made it worse.
