2wd camber bolt popping
Key-in Chime: Silenced!
Smarty Touch and MM3 Owners here!
Hello all,
This goes to anyone with experience in the issue I am having.
To sum it up, I have replaced the lower control arms, camber bolts, sway bar bushings, upper control arms and bolts, ball joints. Pretty much everything except the tie rods and steering rack.
I am still having a loud popping noise when i am reversing and going to the right. If i straighten out or reverse left there is no pop and it only happens every once in a while. I can always pull forward and slam the brakes and it pops back again but not as loud.
I have made sure everything is torqued to spec as required and it still happens. Anything I can do to fix this?
Do you have a GoPro or other camera that you could mount under your truck or on the ground and see if anything is moving that should not be?
Unfortunately I do not. Might have to tape my phone under there lol. I'm betting it's the bolts that holds the lower control arm to the frame.
Best I can do is try torquing again to 190ft lbs unless someone has a spec elsewhere that's different?
