My report was heavily edited in the last issue, but to summarize, Trans Engineer found that the factory fill at BW is Dexron 3.
I don't know about Amzoil, but Dang! That squeeze bottle is the ticket.
SuperTech ATF+4 from walmart last three changes. Still looks new when drained every 25K miles.
I recently found that Valvoline has the bags too....Walmart sells it.
Good to know .I recently found that Valvoline has the bags too....Walmart sells it.
I've considered using ATF+4, mainly because I always have it on the shelf. Dexron not so much. Do you use 4wheel drive alot? Even the severe duty maintenance interval is 30k miles.
As said above, I have used AMSOIL ATF for years and it is fully SYN with no problems and I just last week did my 99 with it after disassembly and re assemble and re install after the 5 gear repair on the NV4500. Like was said it is only gears and chain, nothing special. My 17- 2500 with 68RFE is next as it just turned 40K, I'll get that done before winter.
gtwitch in wyoming
Can you elaborate? Not sure I’ve heard of that before.On your 68 you can do a complete fluid exchange if you want.
Can you elaborate? Not sure I’ve heard of that before.![]()
