Had a 280z towed in once that had a ECM failure and loaded engine. Crankcase FULL of gas. Long and short new ecm,new oil and filter and started motor it tried to do a runaway. Dumped clutch and killed motor. Pulled off air box tube,cranked engine and it did it again. Pulled coil wire. It ran at a POOR rough Idle without the ecm and fuel line hooked up for a good 30 minutres and then died. Restarted with coil hooked up etc and it smoothed out and ran ok. That was a trip!
