My buddy has an '03 2500 and was wondering if his stock 48re transmission can handle what his "Edge E-Z" puts out.
I do have a HTS valvebody
I was told after asking the diesel mechanic at the dealer where i bought it that everything on the truck will handle whatever you want to put to it (responsibly) EXCEPT the torque converter.
I was in no way shape or form implying, nor do i think anyone else on this post was, that the transmission will not hold the power. Asking for advice is exactly what you get. I read this post and thought of what was told to me and thought i would share it here. I agree that the 48re is dodges best transmission yet, aside from a manual, and that it can and will hold the power. the question is not if it will but how long it will.listen, i have a 2006 w/48re. it is at about 440hp/770+tq. i had it on a dyno early this summer 410hp/740tq... ... ..... stock transmission! yes, stock transmission! it has just under 60k now, just did a transmission filter and amsoil last night. guess what, it runs like a raped ape. so, tell me, how can you say it cant hold the power. i also use it for light towing, on tow setting of course. towing under 8000lbs.
its not slipping it does shift oddly at times, only when i'm not getting after it; i run 295/70/17 tires, but again, explain to me how my 48re doesn't hold the power. oh, i have also gone through 2sets of tires and the present ones have about 20k left of tread..... so you can see i'm not easy on it. again this is the same transmission (48re), that i had on my 2004. on the 2004, i pulled in excess of 10k of concrete panels. so, in my experience (2 48re's) i have had no problems running higher hp. i plan on getting a K&P transmission over the winter. so, maybe its the driver?![]()
This is my first automatic with a diesel and I am concerned also. I am looking at an Edge juice or something like that. How do you know if you are loosing pressure?![]()
My Edge Juice with Attitude has a torque converter slip indicator that tells how much it is slipping. It consistently shows between about 8 to 9. 8 percent, which seems acceptable. I have been watching for it to go higher but have never seen 10% or higher.
