I did not index my start wheel or the top torx screw above the diaphragm.
I'm not sure you can index the full power screw at the side. I don't think it would stop against any reference point that would be repeatable on all VE pumps.
I wish could help you on the star wheel. I did the same thing there. Not sure where I was originally for that setting. If I go back in for another adjustment I will take a dial caliper reading from the top where the diaphragm seats down to the inside flat area of the start wheel. Maybe we can get several others to get distance measurements on that. I also lost my factory setting on that but It's running fine where it is. Did you loose your full power screw original setting?
I talked to the Piers Diesel people about my Bosch 190's and how to adjust them. Maybe you can PM BuschWakr on your smoke issue.
Side note. Will switch to an electric fan today for less system parasitic drag. Have to go to the parts store and look for a suitable T-stat. I don't like how the fluidic fan clutch system is always pulling ice cold air through the radiator. I will also start closing off some of the radiator surface for a faster warmup. MOF I better get off ths computer if I'm going to get that done today.
