4th Gen. front end vibration
Four wheel drive front end flop when turning
2025 c&c 4500 and 5500
I have a 2016 mega cab with 35 x 12 wides; truck has 51000 miles on it. Recently noticed when I stightly turn to the right, feel slight vibration on left front; don’t feel it turning it to the left. Anybody have an idea what it might be?
Thanks!
A worn ball joint will act this way but that's really low mileage for one to be bad. An easy way to check is to raise the front end of the truck a couple of inches off the ground. Then take a bar or something and lift under the tire. If the ball joint has play, you'll feel it. I would rotate the tires and see it that effects the vibration. I just went through this with my 2013.
Ok… thanks for the scoop, I’ll look into that!
