Engine/Transmission (1998.5 - 2002) 5.9 24V engine will not speed up
Engine/Transmission (1998.5 - 2002) overflow valve
2nd Gen Non-Engine/Transmission Air conditioner lines
hope ok to to post here not a dodge but a cummins
Ford 2000 F650 24v cummins engine ,will start fine engine will not speed up
foot on the floor no RPM new fuel filter ,air cleaner is that what they call dead pedal, need help truck down ant idea what problem
Thank you
Since you are running a 24V, I am guessing that your problem is the APPS or TPS. Geno's sells an aftermarket replacement relatively cheap. A quick search will show you what it is and you can check to see if you haveone.
Good luck
Could also be "limp mode" if the Ford ECM has that. That's where the ECM intentionally defuels when it can't sense boost or sees other problems. It's a safety thing intended to save the engine.
