Originally posted by RHARVEY
OK here is the report of the install!!! The 4" system is in and sounds great! I went from a stock 3" straight piped system to this 4" with a straight thru 4" in 4" out 30" muffler.
The 30" muffler with the hanger kit that comes with the system works wonderful.
With the way the down pipe is bent. . it gives you plenty of room between the frame and the bell housing and also it gives you more clearance between the down pipe and the firewall.
As far as the dreaded drone at 2000 rpms... there is NONE! Would I buy another system from Big Exhaust... just as quick as I could pick up the phone... .
I cant say what the install is on the 5" but the 4" was a cake walk. I did grind off the tailpipe hanger and mounted it to the new system then I installed my chrome turndown. .
When I get to work tomorrow I will post the pictures in the "Reader Rigs' so that all can take a look at it.
Any questions... I will try to answer them. .
Glad to hear the install is done and product is good. Looks promising. Thanks for the report out.
-Ken
Rick
Casey,
The shipping was $50
mike,
I didn't try the baffled muffler. . it was a different length so when I cut the straight section of pipe it would not have worked for the straight muffler.
I need to back up a little... this system is a 16 guage system!!!
But of what I have seen... it is a clean system. I did test the 2000 rpm drone and I got none! You are getting your moneys worth with this kit! Like I said in my earlier post. . the muffler will hang where the stock muffler hangs. The hangers are welded up when you get them but they work with the stock rubber bushings. They also send a rod to slip in the transmission mount which I elected not to install.
The system sounds so sweet compared to the straight pipe that I ran for over 2 years.
Rick
Originally posted by Dmundell
maybe I should clarify? 4" with straight through muffler as RHARVEY stated above thanks and let me know when
Originally posted by Dkevdog
Is there any possibility of retaining the spare with a 5" system? I was just told that the spare is gonna have to ride elsewhere with a 5" system.
You might check on splitting up the group purchase with 4 and 5- I think there might be some interest in it.
Kev
Two guys at a local Exhaust shop told me that the 5" systems dont allow enough room to pass the spare. I don't know what system he was referring to that wouldn't fit (he says they tried it about a month ago)- only that it would not fit.
I am hoping he is full of BS and that it won't be an issue. Someone set the record straight. I know it's pretty tight up there- mine is tight already with my Hy-Tek cover, but if it won't fit with a 5" system it could be the dealbreaker for some, myself included.
Kev
