Cumminz,
I regret that this learning experience cost you $590 but it is a good reason for an informative discussion for the rest of us.
The thread allowed some of us to dig into our memories to recall and clarify what we learned some time before and others to gain new information and understanding.
My license was OK and got ticket because my truck license tag was for 10k. I did not exceed my GVWs. Neither truck or trailer. Simply I did not have enough tag to cover total load.
X2
Bet most people in PA do not realize trailers over 3K need annual inspections. No one ever did them, but its in the code! (Or used to be anyway).
Cumminz, did he say anything about the ties hanging over the edge of the trailer? Do you think that might have initially caught his attention?
X2
I remember the frustration trying to get answers about 10K GVW trailers out of PennDot years ago. Nobody had solid answers, not the DMV or the Troopers who are supposed to enforce the laws. So what do you do? Bet most people in PA do not realize trailers over 3K need annual inspections. No one ever did them, but its in the code! (Or used to be anyway).
NC has both CDL and non-CDL class A, B & C licences. NCDOT Division of Motor Vehicles: Driver Handbook: Chapter 1
so what does the DMV there give as max tag weight for your truck? Do they use the MFG supplied GVWR or what? where is your allowed max weight stated on your registration?
are they comparing the actual combined weight to the trucks registration allowable weight? in NC, are you required to have registration for your combined weight, at the minimum? here in CA, I register for MFG gross weight (10,500 for my 3500) and max allowable as far as I know is based on combined and the 10k trailer, 26k combined rule. trailer is all by itself
i am getting confused by the slight tangents this thread has taken. am i wrong with my understanding of CA laws as well?
95% of the diesel pickups towing trailers (rv's excluded) on the highway are doing so illegally. This is the first example I've heard of where the laws have actually been upheld.
I went and looked up NC rules for weight and found that its a "declared weight" setup there. Given the section below, I suppose that the OP had his truck tagged for the truck only and did not allow for trailer weights? hence the 9300# overweight?
Chapter 20
§ 20‑88. Property‑hauling vehicles.
(a) Determination of Weight. – For the purpose of licensing, the weight of self‑propelled property‑carrying vehicles shall be the empty weight and heaviest load to be transported, as declared by the owner or operator; provided, that any determination of weight shall be made only in units of 1,000 pounds or major fraction thereof, weights of over 500 pounds counted as 1,000 and weights of 500 pounds or less disregarded. The declared gross weight of self‑propelled property‑carrying vehicles operated in conjunction with trailers or semitrailers shall include the empty weight of the vehicles to be operated in the combination and the heaviest load to be transported by such combination at any time during the registration period, except that the gross weight of a trailer or semitrailer is not required to be included when the operation is to be in conjunction with a self‑propelled property‑carrying vehicle which is licensed for 6,000 pounds or less gross weight and the gross weight of such combination does not exceed 9,000 pounds, except wreckers as defined under G. S. 20‑4. 01(50). Those property‑hauling vehicles registered for 4,000 pounds shall be permitted a tolerance of 500 pounds above the weight permitted under the table of weights and rates appearing in subsection (b) of this section.
Cumminz,
Many TDR members use their trucks to haul heavy trailers at least on occasion and towing often puts us out on the highways where we are visible to DOT cops. It is good to have an understanding of the laws.
I had owned and pulled heavy RV trailers for many years and work trailers occasionally without having a clue until I went to work for an RV transport company in January 2005. That company, Horizon Transport is one of the most professional in the industry. Horizon operates and requires its drivers to operate in strict compliance with DOT regulations in all states. I learned a lot in their orientation training and from my time on the road for them. Later I worked for another company that required me to pull heavier trailers (over 26k combined) so I got a CDL with ease because of what I had already learned. I don't haul commercially any more but it is good information to know.
Any state can enforce more stringent rules, Federal regs are an absolute "minimum" that must be followed by the states... but the states can enforce any rules they want provided they are more restrictive.
There are two exceptions to this... the state simply adopts Federal regs for their own, or the state accepts less Federal funding and has their own regulations (as with MI and KY, both states allow more than 80k pounds on highways within their borders provided you follow their rules).
I thought 102" (8'6") was max width and after that it is considered a wide load? Is 102" the incorrect maximum federal width?BR.
He did pull out his tape measure and measured their width. It was 8'9"s. He did make a comment but did not cite me. Good thing,,, they were even with the fenders and my dually flairs were even with the width.
