Engine/Transmission (1994 - 1998) 5th gear
  • Thread starter Thread starter LJ
  • Start Date Start Date
Engine/Transmission (1998.5 - 2002) How do I get the valve springs off?
2nd Gen Non-Engine/Transmission The dreaded drone is gone!
can anyone tell me if this is part of the fith gear nut problems? when in fith gear it will intermitantly pop out of gear when i let off the gas it also sounds a slight bit louder in fith compaird to the other gears i hope its not more serious thanks
LJ,
I'll give a stab at this. I don't know if the 5th gear being loose will make it pop out of gear but I do know that if the gear is loose it is hard to go into 5th gear. The shop manual says that the transmission will slip out of gear if "misalignment or damaged shift components or worn teeth on the mainshaft gears or synchro components are evident. " I believe also if the syncro struts and springs are not working properly, the transmission will slip out of gear.
The noise from the 5 gear is because of the wear on the transmission and what you hear is all the worn clearances on the parts. (did that make sense?) I just rebuilt mine and 5th gear noise would drive you crazy. After the rebuild, no more noise. Hope this helps.
WD
thaks for the replies I believe your right I think the noise does sound like a bearing ill just have to pull it apart thanks again.
