Are you sure you want to do that?
Adding a fifth wheel kingpin assembly frame to an existing conventional travel trailer would probably add 1000 lbs. of steel and six or eight feet of leverage to the frame of your travel trailer. The additional stress the modification would create would probably cause frame failure if you pull it enough.
