Starting to be out of ideas what to try next. Output speed sensor didn't help either, still stays on first gear. I tried another PCM but no change what so ever, although both of my PCM's are used and I don't know why they have been removed. Earlier tried with another valve body, no change. The trans. has been opened and clutch/servos tested with pneumatic air, they are working like they should be. I have on shelf a brand new solenoid pack, the one which controls od and tc but already tried with another valve body, so I don't believe they will do any good. Measured all the wires from the trans. to the PCM, all ok. I also measured all the solenoid coils from PCM connectors, they are around 33 ohms each and they can be activated by feeding 12 volts from trans. relay and grounding corresponding wire from the PCM connector, they draw about 0. 34 Amps each. Maybe I just gotto keep checking all the wires and grounds related to trans. control. The wires for the transmission are the only ones without any mods. I just plug it on like it was and now the damn thing is the only one which is giving troubles.
Timo
Timo
