2nd Gen Non-Engine/Transmission 94-01 Steering Wandering Count!!
Engine/Transmission (1994 - 1998) fuel pours out
Engine/Transmission (1998.5 - 2002) Ats nv4500
'02 QC 4x4 New steering box, new ball joints, numerous track bars, two different sets of tires,and a decent alignment shop fixed the ongoing prob.
p/weez
Just picked up a '01 3500 CTD 4x6 w 185k/ wonderful truck/ steering wander/horrible/just placed order for the RIP adjustable trackbar fix/hope this helps
still have wander 1 track bar 1 steering wheelshaft several alingments tire rotation and of course I have DSS time for an aftermarket steering box,trackbar, and steering wheel shaft soon
Crap. Need ANOTHER track bar. lat one April 04 at 68k. now 99. 5k. These do not last real long, do they? This is the last free one. When it fails I will hope someting better is out there.
Replaced under factory Warranty??
Are they replacing your track bars under the 7 yr. 100,000 mile power train warranty, or did you buy a specical extended bumper to bumper warrany? My dealer says that the track bar is only covered under the 3/36,000 bumper to bumper.
let me know... . i may see him again. my first one failed @ 36000... now have 48,000 and wander is coming back, i think. they also replaced upper ball joints @ the same time.
Thanks, David
OOP's, doubled up on this post
Yesterday, 11:58 PM #332
DLMcpherson
Online
Thanks, David
__________________
ott 2 SLT Auto 4WD, 354 Gears, Camper Special, Factory Towing, Trip Computer, Quad Cab Long Bed, 4W ABS/Disk Breaks... . Dave the Mopar Man
If steering wheel turns 4&1/4 lock to lock, replace with box that turns 3 turns lock to lock. Call "Chip" @ Power Steering Services Springfield Missouri 417-864-6676. You will not be disappointed, Jim 321 373 5756
I AM WANDER FREEEEEE!!!! Today now 6 years later and 77,778 miles later ... .
New quad 4X4 Ball joints, Rod ends , drag link , steering stabilizer along with my existing DSS , DT Track bar.
MOOG now has a series of heavy duty fleet parts called "Problem Solver" Series. I can tell you theese rod ends are bigger , and have a much more stout grease reserve and dust cover. I will let yall know how long theese will stay tight.
94-01 Steering wander
95 CCLB 5 speed, still wanders despite having been aligned several times by different shops. I have a 92 W250 with 245,000 miles that drives better! Lektrikman.
My 98 Ram with 99,000 was terrible and now drives like a car. Turn your steering wheel lock to lock and count the turns. 3 turns and you have the correct ratio box. 4 & 1/4 turns and you have the WRONG box intended for larger trucks. They look the same but are different on the inside. Chip at power steering services in Springfield Missouri does a super job of rebuilding if you have the wrong box. That is where I was told to get mine. He will exchange with you (faster) or rebuild yours. REGARDS Jim 321 373 5756 anytime.
That's interesting. I just replaced by stock box with a dealer supplied Delphi unit that is 4+ turns lock to lock. Aside from difference in the number of turns lock to lock, are there any other benefits to swapping in a 3-turn unit?
Ryan
Based on my own experience with my Ram 12v when I replaced my 4+ turn box with a 3 turn box it solved the wandering problem. I did this on the advice of "Chip" at Power Steering services. My wandering problem was bad and now my truck steers as well as a car. I can't imagine any advantage to having a 4+ turn box, they do not belong in a Ram, they are for larger heavier trucks. They look the same on the outside and the wrong box was installed in my truck at the factory. After 7 years of misery I now have the truck I should have had in the first place. Jim 321 373 5756 anytime
It has been mentioned before but should be mentioned again. The alignment will contribute to the wandering problem. I had almost no wander before my last alignment(after installing a DSS, 3rd Gen trackbar, and new tie rod ends but before the alignment) but following the truck's alignment the steering is noticably worse.
