My brother called me with an issue on his 96'12valve, the truck is stock (that i can tell) except for the star wheel pushed a little. last week the truck started having a lope issue at idle and would not make any power or stall off idle and lots of black smoke. I checked some basic stuff and found that the waste gate acuator was rusted through and the puck was stuck wide open. had him replace that and throw in a boost guage i had laying arround. the truck idles a little better but it still has no power off idle. I have him getting stuff together for installing guages boost, fuel pressure ,EGT. till then I was hoping to hear some thought from you on what the issue could be? heres the issues...
1-Truck in drive or reverse foot on the brake slight lope at idle about 800 RPM
2-Pulling away from a stop little to no power heavy black smoke
3-Truck in drive or reverse and brake torque it and it will smoke heavy black no power no boost building. and the rpms will not come up even when floored. let off gas ped and it dies.
4- test drive down the road very weak off idle lots of black smoke but once moving the truck seems to function normal#@$%! boost levels arround 18psi.
I know I need to get you guys some fuel pressure readings still but any thoughts at this point would be good.
Thanks.
Thanks.
