2nd Gen Non-Engine/Transmission 99 TDR QC,4x4, auto , Radiator drain plug p/n
2nd Gen Non-Engine/Transmission Glove Box Fix
2nd Gen Non-Engine/Transmission Rear Bump stops 2500
BK
So my radiator drain plug is leaking on and off.
I've searched all sorts of parts sites, and no one lists a number for it.
Tried a few different mopar sites, nothing.
I tried Dorman's site, hit Pepboys, Autozone, nothing (only ones by me).
I found another forum that listed a Dorman p/n 61134, found one at Pepboys, it's OD is too small to be right. The basic screw/thread mechanism looks like it could be right, just too small.
Anyone know the mopar or Dorman p/n, and or some place on the web selling them?
TIA
-Bob
1143
As GAmes indicated, unless the plastic plug is stripped or cracked, the o-ring should do the trick. Take the plug with you so you can size the o-ring correctly. I used a green o-ring (refrigerant line type) when I changed mine. Tip: If you can find some plumber's grease, white grease or even Vaseline, put a schmutz on the o-ring so when you want to drain next time its not locked up.
I didn't think about it being stripped or cracked. If it is, PM your address to me and I'll send you the one out of a radiator I replaced. Long ago I quit using the drain because it was so difficult to get to and prone to leak. If I need to remove the coolant I siphon it out.
1260
Thanks all.
Yea, it's probably just the O-Ring, my neighbor had a great kit of the green O-rings, and offered it up.
But I was trying to do a quick swap right now, with only getting a little wet, rather than drain the system.
So was looking to buy a new plug w/ O-ring for the quick swap.
I too stopped using the drain plug after the first drain/flush/fill.... just pull the bottom hose.
But , it's leaking, worse at time, better others.
I spent the weekend going nuts trying to find it on line, nothing, can't believe it.
Not even Geno's.
I found the bad info on another forum..
Was hoping somewhere here had a source.
I hate dealing with the local dealers, but guess I'll have to, or wait till the spring, and do the o-ring when I drain/flush/fill, it's just about due.
In the mean time, hope someone here comes across the number.
I should make it till the spring, it's not bad.
The seal on the output shaft of my steering box is leaking worse.
And I just read the Borgeson's aren't available, and weren't worth it, and had their problems. I almost did one this summer, finally procrastination paid off.
GAmes, thanks for the offer, but you should hold on to it... seems it's worth it's weight in Gold. ! LOL
I have two Dodge radiators in the scrap metal pile and a used spare in a storage shed. You are welcome to the drain plug, it is sitting on my workbench.
