Long story short: Can an A/C compressor with low compression be rebuilt?
Just so everyone is on the same page, to start my A/C system is leak free. I removed all the air from the system and started to pump freon in. I got the correct amount of pump oil in (6. 4oz if I remember correct) and started to put a can of freon in but ran in to a few odd things.
1) Both the high and low side had the same size port for the gauges so I can only monitor one side at a time.
2) I started to add to the low side line and started to get crazy pressures (around 100psi) after the compressor was running.
3) I also had just a little more pressure on the high side (around 160psi) also after the compressor was running.
4) The compressor will kick on for a 10 seconds and turn off for 10 seconds with the rpms at 1500.
So heres where I'm at, new condenser, new high and low side lines, new dryer, new pressure cycle switch, and all new seals on every thing. The only thing I haven't replaced is the compressor. I had high hopes that I wouldn't have to replace it because it kicked on and seemed to be cycling at a regular rate. I've come to the conclusion that my compressor must not be completely compressing the freon. I searched around for a compressor rebuild and had no luck. I really don't want to replace my oem with a sloppy remain part for a quick fix and don't have $1500 for the new oem the dealer quoted me. Anyone know aside from special tool if I'll be able to rebuild my compressor? Maybe a few part number? The truck is a 1994 and is r134a system. Any help would be awesome, cheers nick
