My truck is a '99 and I replaced my evaporator coil in the fall of 2002.
The original equipment failed in the spring of 2002, the dealership re-charged my system with dye containing refirgerant. That lasted three months. Back to the dealership only to be told that everything under the hood looked good, so the problem must be in the evaporator. Service manager said "gunk, like leaves and other stuff, get's lodged in the bottom of the air housing and rots out the evaporator coil". Estimated service charge to replace the coil was +$850 and a full day in the shop. No thank you... .
I was not in a position to pay that kind of money, so I pulled the evaporator coil myself. Parts $135 for the coil, another $10 for the plastic tool used to remove the coil from the pressure and return lines, and another $100 to recharge the system at a local service garage. About eight hours to do the work of removing the dash board completely, pulling out the air box (the mounting bolts through the fire wall are a pain in the butt) , splitting the air box, replacing the evaporator, and re-assembly. Pay special attention to the motorized damper position for hot/cold adjustment... recommend moving it to full cold position before disconnecting. Be sure to correctly engage the drive shaft of the damper into the motor when re-assembling... or you will find yourself pulling it all out a second time like I learned (the hard way).
More than a year since I replaced the evaporator... and still working.
This is the type of expensive repair work that fumes me #@$%! ... engineers know that junk will be sucked into the air handler, so design accordingly.
Good luck with your situation.
