Hello all,
New to TDR and the very first post
well here goes.
Got my first oil analysis back with a high Silicon level of 22 ppm. Lab states that the high levels suggest that it is not from silica (dirt) because of low wear rates. Lab questions a silicone sealant or gasket material may be present. What would introduce silicone to the oil. This sample is from the second oil change not the factory fill. The oil is DELO 15W-40 with 5100 miles on the oil and 8000 total miles on the engine. Is this typical with a new engine? The lab is Herguth in Vallejo, CA
Thanks, waterdonkey
TBN 9. 52
Vis 13. 46
Soot <0. 1
Oxidation 8
Water <0. 1
Sulfination 5
% fuel < 2. 0
% glycol <. 10
Iron 36ppm
Al <1
Cr 2
Copper 12
Lead 3
Tin 2
Nickel <1
Silver <1
Silicon 22
Sodium 5
Boron <1
Zinc 1541
Phos 1314
Calcium 3251
Mag 8
Barium <1
Molybdenum <1
Vanadium <1
Thanks, waterdonkey
TBN 9. 52
Vis 13. 46
Soot <0. 1
Oxidation 8
Water <0. 1
Sulfination 5
% fuel < 2. 0
% glycol <. 10
Iron 36ppm
Al <1
Cr 2
Copper 12
Lead 3
Tin 2
Nickel <1
Silver <1
Silicon 22
Sodium 5
Boron <1
Zinc 1541
Phos 1314
Calcium 3251
Mag 8
Barium <1
Molybdenum <1
Vanadium <1
