Team,
Does anyone know if an always-on ABS fault light can be related to dirty wheel sensors, a corroded wheel sensor connector, or other less costly fix? Will flushing the "old" brake fluid help in the pump or fluid flow sensors? It was an intermittent, but now it is always in alarm.
Being an '18 CTD Big Horn, will my Autel code reader be able to read or reset the ABS code if I use the 12 + 8 Connector Diagnostic Cable Fit for Chrysler Autel? And, when I enter my VID intheAutel, it defaults to a 2017 Ram is what shows on the Autel. As I understand it, in 2018 model year, Chrysler created a "firewall" to prevent altering alarm algorithm settings and resets.
Thanks in advance,
