Signature Truck: 2014 Ram 3500 10,000 miles. Outside temp anywhere from 40° to 70°F.
It's happened several times, but tonight I verified the AC Compressor was actually spinning.
Driving along in my automobile... and it starts getting colder. This seems to occur within a few minutes of climbing a hill. The temperature selector has been anywhere from the coldest, but not on Max A/C to mid-way, with AC off every time. The position selector is in Dash vents, and once or twice blended with floor vents, but never anywhere near defrost. If I press the AC button to turn on the AC, wait a second and then turn it back off, the air starts to warm back up.
Tonight when it happened, I stopped in a parking lot and verified the compressor was spinning, (the actual compressor and not just the outer ring of the pulley, i.e. the AC clutch is engaged). I turned on the AC and verified the compressor stayed spinning. I turned the AC off, and the compressor stopped spinning, as suspected. I went through the drive through at Dairy Queen and shut the truck off at the order screen. Halfway home, about 2 miles, I noticed the ventilation was getting cold again. I cycled the AC and the air warmed up.
To summarize, when I go up a hill (unfortunately I can't quantify the hills or angle required to do this.), the AC compressor clutch will engage on its own, until such time as the clutch is told to disengage. I have not knowingly let this go long enough that the compressor clutch would cycle on its own... maybe next time.
Any guesses?
Any guesses?
