Adding Ball Valve to Bypass Oil Filtration System?
ditched the twins, went super phat!
amsoil bypass or other?
I, recently, purchased an Oilguard Bypass Filtration System for my '03, 3500.
I'm thinking of installing a ball valve between the stock full flow filter housing (where you tap for the feed to the bypass) & the Oilguard. The ball valves seem to have a silicone or plastic housing that the "ball" sits in. My question is, will this silicone/plastic housing hold up to the heat of the motor oil?
I would like to do this so that I can block off the flow to the bypass, if needed. I'd like to be able to isolate the bypass system in the event of a problem with it.
Is there a type of valve that would work better in this application?
Thanks.
Joe F. (Buffalo)
I carry the plug that came out of the housing just in case of hose failure etc. In my opinion I would not add the ball valve with hot oil circulating thru the system. It could lead to problems you would other wise not have such as a leaking stem, plastic breaking clogging the system etc. Maybe contact Oilguard and ask what they could recommend or maybe they have a valve.
Dave
Would it not depend on the grade of the valve?? I know some that can handle steam all day long without issue...
steved
Steve, funny you asked this. Today I was thinking about putting a valve of some sort on my Frantz when I install it. Like you, I like the idea of just being able to turn a valve off in event of trouble/leak and fixing it at home. If you would; pm me of your solution in case I miss it if you post it. Thanks
Solid brass ball valves come to mind.
I have a RACOR bypass system which is much like the Oilguard. I had a 1/4 npt bung welded to the bottom of the steel cannister so I can drain the cannister prior to changing the filter. Without draining the cannister before changing the filter it gets really messy.
Bob Weis
