In "light" of recent threads I checked the voltage to my headlights. It was 11. 7-11. 8 at the headlights and 14. 5-14. 6 at the battery. Lights need full voltage.
I got the crazy idea to add a couple of relays to each light, triggered by the factory wiring. This was inspired by hoping to not go HID, by Danniel sterns web site.
To make a long story short, I got it wired in and used the factory wiring as the trigger for the relays, and power from the battery. I found that the light out warning system will not keep the relay triggered, causing it to pulse. Just like there is no bulb in place.
Is there a way to make the relays stay engaged and still use the factory wiring as the trigger for a relay set up. Or has Dodge done the ultimate in darwinism protection for the tards that can't tell if a light is out?
