adjustable hitch for my receiver???
Sprinter Camper
Anyone with a Loong trailer?
i'm looking for a height adjustable hitch for my reciever. must be a class iv and must move around enough to tow everything from a 12' duck boat to a 30' tt...
what are some of you using for this? where can i get it? how much???
thanks in advance... .
We use a Reese that is adjustable by removing and reinstalling 2 large bolts. It covers our range of towing needs.
Reese Equalizer Hitches in varying weight requirements
I have been thrilled with my new "Rapid Hitch" www.ultrahitch.com I got the one with a 6" drop but a 10" drop is also available. It has a solid aluminum structure (except the balls and lock pins) and has a trailer rating of 10,000 pounds and tongue rating of 1,500 pounds. It is adjustable in either the up or down position. I got the hitch ($135) which included one flipover double ball (I got 2" & 2 5/16"), I also got the accessory ball (1 7/8") ($16) and a set of keyed alike locking pins ($39). Contact "Warren Ross" at "Anderson Manufacturing" 1-800-635-6106 Ext. 1103 or -- email address removed --:) :) :)
adjustable hitch
If you don't need the equalizer bars then try this link.
If you do need the bars then check out the manufacture for part numbers and start searching the web. I found my Reese adjustable weight distribution head at the local Les Schwabs
