Engine/Transmission (1994 - 1998) AFC gutted
Engine/Transmission (1998.5 - 2002) fuel hose
When i bought my truck it had no fuel plate. I put the plate in yesterday but also noticed that my AFC had been gutted. Is there anywhere to buy parts for it or do you have to buy a new AFC?
On a side note i tightened my governor springs 2 clicks to up my RPMs. With the tightened springs and the fuel plate I elimated most of my smoke and it also feels like it has a lot more power until i lock into overdrive. When that occurs I lost power. Is this going to hurt my pump any? Overall I like the set-up. How much will the AFC make a difference? It will not make a difference in over drive, but it will help with my low RPM smoke correct?
Thanks for any input.
Jeremy
Hello. I have the lever or arm from inside a 215hp pmup that I do not need. I don't know what more you need. I can at least supply that piece if you want it. . Marc
Im not sure what all is missing because ive never seen a complete one. . so this next week while im at home ill look at my brother in laws and see what all i need. Thanks a lot though.
Jeremy
The rod is there. I think what is missing is the arm and is there a spring that goes onto the arm?
Thanks for the picture it helps a lot.
