Air Bag Light On
Front axle shaft damaged
Will not start
ETurner
My air bag light came on when I was on vacation. My cruise and horn works so it's not the clock spring. My buddy owns a trans shop,had him scan it with a snap on scanner. No codes. Told me it has to got to dealer. My dealer closed. Can someone recommend a dealer in the south jersey area. Thanks
Jhenderson,can you tell me where that switch is located?Did you replace it or just clean the contacts?Thanks for replying.
The switch is operated with your ignition key, and is next to your glove compartment. I removed it from the dash and cleaned the prongs and bent them slightly for better contact.
