I want to keep my setup simple. I have a belt driven air compressor with a 1/2 line going to a 2. 5 gal air tank. See here for details:
It goes thru an air manifold and regulator. I have an electric air pressure gauge mounted on my pillar. You have to have the key on to know the air pressure.
I was thinking of plumbing the ping tank this way:
Air tank to pink tank using 3/8 line with a check valve ( for drain back ) and a ball valve valve ( for manual shut off )
Pink tank to regulator and gauge ( mounted in the cab ) using 1/4 line - not sure where to mount it just yet
Regulator to tee and then out to the 2 bags using 1/4 line also.
I will use compression fittings with inserts - no push on line fittings for me. The push on hose that came with the Kilby kit got replaced with stainless steel wire braided hose, with plastic inside, just like a Kenworth would use coming off their compressors.
I live in a climate where we get get snow and cold temps so I can't have solenoids under the truck.
My main load is my TT so I don't think I need to have each bag separately controlled.
David
