I just wiped out an injection pump on a 2002 2500 with 78K miles because air was getting in the fuel line with no apparent affect on fuel economy or power while pulling a 9K trailer! After traveling ~150 miles when braking to turn a corner the engine just quit. Would not start until front injection line was bled of air. Reached my destination 12 miles away by running smoothly between 800 and 1500 rpm at what seemed to be full power, but every time I let up on the throttle, the engine would die and need bleeding to start. Would not run smooth at any other rpm than 800 to 1500. This all happened with an Edge at #3 setting. After cooling off for a few hours the engine would start by turning the key and running the transfer pump twice (only got 2 or 3 psi on the pressure readout each time), then turning the engine over for 3 or 4 seconds, then turning the key back but keeping the transfer pump on for 3 or 4 more seconds to get normal 13 psi fuel pressure at inlet to injector pump, then engaging the starter to start engine. The engine would run, but not run smooth at any rpm!
Replaced the injection pump and engine started and ran fine until stopping using brakes which resulted in engine dying and air in fuel line. Engine will start using above procedure when worm and when cold, will start almost normal with the exception the engine must be turned over 6 or 7 times instead of 1 or 2 times. Every time the truck is stopped with the brakes the engine dies and air somehow gets in the fuel line! I'm thinking of putting clear temporary fuel lines between the fuel tank and rear, frame mounted stock transfer pump and if needed, between the transfer pump and fuel filter to try to determine where the air is getting in the fuel line.
Has anyone got any ideas relative to what's going on or other diagnostic suggestions??
