2nd Gen Non-Engine/Transmission Aluminum wheels
Engine/Transmission (1994 - 1998) how do i adjust wastegate rod
I am almost positive they will, it is the older 12v trucks that have a problem fitting over the rear drum because of the backspacing. Hopefully someone will chime in with a concrete answer.
Is it 2WD or 4WD?
On a 2WD, if the rear drums are reduced in diameter by 1/4", they will fit. It won't weaken the drum enough to be of concern. The fronts fit fine.
On a 4WD, there may be interference with the tie rod ends as well, but I have no personal experience with 4WD.
Yes the truck requires a bit of modification to install '00-'02 wheels, with the tie rod ends and rear drums on both 4x2 and 4x4s as I recall.
I'm taking the easy way out and installing factory 17s on my '96, I just picked up a set with factory BFGs that have about 40% left for $325. Can't wait to put 'em on tonight. Will post results and hopefully pictures tomorrow.
Vaughn
Vaughn
Got the wheels on last night, pics in Reader's Rig album under '96 Ram. Vaughn
315's?
Dl5treez said:
They really fit tight under the wheelwells... . 315's look sorta small.
Dl5treez;
What is the series or aspect ratio of your 315's? Do you have a lift? I am planning on Toyo M-55's, but wouldn't mind going bigger if they don't rub @ full lock with stock height. I also have a set of '00 - '02 alloy's I am going to install. Thank you, Tony.
Similar threads
