Most don't know that when in the regen stage you must drive the vehicle for 45 minutes and no less that 1700 to 1800 rpm's without interruption or the process will not complete itself.
Are we to believe that Dodge/Cummins has given us a machine that will ONLY "complete" a required cycle IF it happens to occur when an "un-interrupted" 45 minute stretch of 73-77 mph driving is in process? I. e. , a 55-58 mile stretch with no traffic lights, etc. , at over-most-legal-speed-limit speeds (with a 3. 73 rear axle in 6th gear - usual gear for level running at this speed)???
Does everyone have such a stretch in their usual commute or daily drive? Is there a guarantee, somehow that the ECM will sense this stretch,... and the BEGINNING of this stretch, at that, ... and begin the process with sufficient drive time/distance ahead to complete the regeneration?
Or are we doomed, by this "plan", to experience X% of incompleted cycles, due to the real (Hello!) nature of normal use, with resulting inevitable increased contamination of the DPF?
"But officer,... my truck had begun a regen cycle,... and I couldn't slow down or stop!"
Is there a "Dive! Dive!" type alarm which goes off to insure that the driver is aware that the cycle has begun (in case he isn't attentively and constantly watching his exhaust), and can then, if nothing else, while caught in stop/go traffic, down shift or sit in neutral and rev. his engine for 45 minutes, to the irritation and consternation of any nearby drivers, particularly the non smoke-lovers? Road rage anyone?
"Fired? But Boss, my truck started a regen just as I was about to turn into the parking lot,... so I had to stay on the road and drive another 45 minutes! You understand, don't you? Don't you have a Dodge?"
This is REALLY hard to believe!
RHaber, no offense intended, but your post histgory shows a total of 2 posts at this web-site. Your profile gives zero info about you, and I don't have time to search through the 2,300,000 links found after a "R. Haber" serarch.
Would you mind explaining how it is you have this "regen" info,... i. e. , what is your authoritative source?
Would certainly be interested in hearing more about this.
