Did they do the flash 18-033-07 that has been out for about two weeks? If it is idling rough, misfires, blows black smoke you should shut it off for 30 seconds and restart it. If you don't, it will soot much faster and plug the PF. The flash corrects it. Your dealer should also know there are two parts of the flash. The first is downloading the "Bootloader" flash, then they have to blow out the files and download the actual flash. There is also a new flash coming, hopefully next week. It should have some tweaks to the regeneration process.
Wow, am I glad I settled on an '06 six speed truck. I think the majority of the blame needs to be placed with the EPA. Those clowns think a diessel should be as clean particulate wise as gas engines, that is what caused the need for all of the garbage bolted to a perfectly good engine. The exhaust system alone scared me when I looked at it, this regen cycle is insane.
So how often do you estimate you can go between regens? How often do you need to road trip the truck to facilitate this BS? I know I personally would have to go WAY out of my way to find a suitable stretch where this regen could take place fully, and I suspect the majority of owners are in this pickle.
The beautiful irony in all this is that we are talking about an emmissions reduction system that requires a boatload of EXTRA high speed driving to maintain its efficiency. So how much extra fuel gets burned during this out of the way driving to get the regen done? I would bet anything that in the end you will actually pollute MORE in order to satisfy some EPA dimbulb requirement. All of this at the consumers expense and inconvienience.
Shame on Dodge for making the system so obtuse, shame on the politians for fabricating another worthless scheme with no common sense behind it. Good luck with a solution. I would guess that the best, though illegal, solution is to find a way to remove the emmissions system. This situation is so stupid it is scary.
No offense, but I stated this thread & my truck is the cab & chassis. Its not just pickups having the problem, its all 6. 7's period. I will say again I love this truck... but this problem is not going to go away until enough of us call Chrysler & make them realize that there is a bad design or a flaw in there design on the PDF...
I love this web-site & think everyone pulling together we can make Chrysler listen up & fix this nagging problem... My last truck (2001 dodge chassis) never went to the dealer for anything. It is still going with 340,000 mile on her. . Best damn truck ive ever owned...
No offense, but I stated this thread & my truck is the cab & chassis. Its not just pickups having the problem, its all 6. 7's period. I will say again I love this truck... but this problem is not going to go away until enough of us call Chrysler & make them realize that there is a bad design or a flaw in there design on the PDF... the rest of the truck is great. Its not the fuel, not the way we drive, its not our fault, its just a bad design & the need to address it now. . !
If you are one of the lucky ones that hasnt had this problem yet, your days are numbered, its only a matter of time. I dont know what else they can replace on my pdf . The check engine light is on again & I can’t miss any more work... I love this web-site & think everyone pulling together we can make Chrysler listen up & fix this nagging problem... My last truck (2001 dodge chassis) never went to the dealer for anything. It is still going with 340,000 mile on her. . Best damn truck ive ever owned...
Another update... . Chrysler is supposed to be coming out with the mother of all re-flashes that is supposed to fix all the pdf problems in the next 2-weeks... It’s being tested & they are putting the final tweeks in it. . Lets all pray this one works...
Oh man, this isn't good. At 4k miles on the clock, my MIL light came on tonight. I have only run Exxon and Hess ULSD, and have Rotella oil (Cummins approved) in the case. Will be at the dealer at 8am tomorrow.
The only other issue I have had, was the change oil indicator coming on 300 miles after my first oil change. I reset it and has not been an issue since.
I don't want to part with the truck, but I certainly don't have the patience for this BS some seem to be having.
