Amsoil Dual Bypass w/ Twins?
electric trailer brake controllers
Biodiesel Workshop 05/22/05 So. Cal. (Pasadena)
I'm getting ready to put on my twins, but have a dual bypass system with the CPFF adapter on it. Will the bypass system still be usable? Or will it be impossible to make fit? Just looking for someone with any experience with trying this, so I don't have to figure it out the hard way...
Thanks
I dont have twins yet but the relocation adapter takes up far less room than the standard oil filter. I dont know where you mounted your filters but mine is mounted to the bottom of the radiator core support. I am sure that twins will fit.
I don't see where you will put the filters unless you lose a battery or relocate them down on the frame rail or where diesel bomb put his--chris
didn't see you post sorry. .
I went down to 1 battery, with the power of 3 :) I used a Odyssey 2150 on the driver side. . moved my bypass mount to the fender wall on the passenger side. re-did all the battery cables on both sides [several grounds only on passenger side that need dealt with]
