..... I'm starting to think about a somewhat plug and play version on the bus APPS. You take the APPS bracket off, you swap the APPS (2 screws, no adjustment, just screw it on), plug the OEM APPS connector into a box, plug the bus APPS connector into the box. Done, crank her up.
Just had a thought... The bus APPS has upside-down logic that pulls the lines to +5 volts instead of ground. Rather than using relays to reverse the logic, it might work to just put a resistor from each of the bus IVS lines to ground, and switch the idle and not-idle lines between the bus APPS and ECM. When the bus APPS pulls one of the lines to 5 volts the ECM would see that, and when the APPS releases the line the resistor would pull it to ground and the ECM would still be happy. I'd try 1K resistors.
I don't have a bus APPS to try it out, but if anyone else wants to...
Karl
Karl, Let me see if I got this right. After adding the 1K ohm resistors to the bus IVS you would then "X" the idle/accelerate lines coming from the ECM. So "idle" from ECM would go to "accelerate" to bus IVS and vice versa. This way when bus IVS idle was hot the ECM accelerate line would see an "open' circuit just like it's supposed to.
Can you post a small schematic. I've got to think about this for a few seconds but think it's genius. would the lines from the ECM go after the resistor (between resistor and ground) or doesn't it matter? How do we figure out what resistance would be best? Wouldn't want to send some stray voltage back to the ECM. That could get exspensive!!!
Mike
ps: i'll have time this weekend to play with this.
Does anyone know how much current the 5-volt supply can safely put out?
I think you're right on this. I was worried about sending voltage back to the ECM in a way it didn't want. A simple check of the voltage on DC pins 6 & 2 when they're active should verify that 5 volts is there but really... what else would it be!
Let me know if you come up with a different resistance value. I should have a few 1k's around.
This will simplify things quite a bit if we can drop the relays from the mix.
... Does anyone know how much current the 5-volt supply can safely put out?
... Besides - it's sorta fun, now that we know more about what we're doing!
I think the schematic of the IVS wiring shows ground, but it is not really ground. I think the ECM knows it is in idle or throttle by sensing some voltage (. 5 volts?)...
I could rig up a small pot to the IVS supply (wherever I tap it) and back off on resistance until the supply voltage start's to drop. Measure the remaining resistance and you could come up with a "never to exceed" amperage.
Do we need the resister at all? The OEM APPS is sending that same 5 volts right to ground when it throws to "idle" or "accelerate" so maybe the load is being handled in the ECM as is. Just a thought.
That is why my 0222 code is showing up because I really did assume the IVS back to the ECM IS ground. On the relays I put the ground side of the coil to that IVS "ground", and I tied the ground side of the relay switch to the same "ground". Which probably provides a slight voltage, but by the 0222 code not enough voltage.
I now think that the ground side of the coil needs to go to battery ground (true ground), and the ground side of the realy switch needs to go to the IVS ground and maybe a 50 ohm resistor needs to be in that line.
The dc IVS circuit has some resistance in it and the bus IVS circuit just has to match the same resistance.
Bob Weis
