HEMI®Dart
Add another Majestic prepped Holet HX-40 to the blown list. Exactly 2 weeks and 90 EASY miles its been on. I filled and pressurized the center section with oil before I fired it. Cold side impeller now has 1/4" side to side movement and some fore & aft movement. It won't build any boost. Starts making noise at 1/4 throttle. It still spins though. Only hit 35 lbs boost, then it let go. I don't have mega fueling or excessive EGT's.
Never had a hot turbo shutdown. Probably a bearing like you guys said. I'll pull it tommorrow and send it back to Majestic Monday. UNBELIVEABLE
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7º, JRE Stage III #4 plate 270/675, AFC spring kit, High performance delivery valves, Piers prepped HX-40, Governer spring kit, ATS Pulse exhaust manifold, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno's Exhaust Blanket, Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 05-12-2001). ]
Bill R
