Well my Smarty came in today. Here's my thoughts.
#8 - TST on 3/0 & 2/0... Undriveable in the state of CA. I actually had it loaded for about 5 minutes and pulled over on the side of the road to undo it. Way to touchy of throttle and it smoked so bad it's embarrasing. Yea, it's a rocket ship off the line. But actually not fun to drive on a daily basis. Something will break if you're not careful (ie. transmission)
#3 - TST on 3/0 & 2/0. Not bad. My TST/EZ stack had more power via seat of the pants. But good throttle response. I'll never load it again.
#6 - TST on 3/0 & 2/0... Still to touchy but better then both #3 and #8. Smokes a ton. Not good in CA. Undriveable down the freeway at cruising speed. Truck surges really, really bad. You can't maintain a set speed, regardless of cruise control.
#7 - TST on 0/0... About the same as #6.
I still have to try the #4 & #5 settings (90hp).
I did unplug my EZ so I'm only running the TST/Smarty stack w/90hp injectors. No matter what I did for timing, either TST or Smarty I couldn't get it to stop pinging because of to much timing at WOT. Even when I had the TST off and only used the Smarty timing. I tried a few other TST settings while driving. Like the #3 w/the TST on 2/2. Pinged really, really bad when I got on it. And with those setting I'm way underpowered compared to what I normally run.
I will say this. The Smarty wakes up this truck like no tomorrow. Man a rocket ship off the line. But my upper end hp is all but gone.
And yes it does fuel well past redline.
Temps did drop at WOT on all runs.
Still got to play with it a bit, but as of right now, I don't think I really like it.
Any thoughts on what I should try. I've heard there might be some downloads and I checked MadElectronics website but it didn't say what the down loads do.
EDIT. I'm in no way dissing this thing or slamming it. I like it and I want it to work. I can see the benifits of it (ie. low end hp) but I'm more frustrated then anything. Could it be the injectors or the cam or that it's an SO truck? Still go to keep playing with it. Not giving up on it. I'll try what ever you guys think might help.
